Beovision Harmony speaker cover adjustment
Those two i just circled in my last picture pull the harmony wings in or out. They have no effect on the screen distance at all. Pull the plastic cover tabs out and you need a 4cm 3mm allen key, they’re fairly deep. Clockwise they pull the ends of the wings in iirc.
If you installed it yourself i doubt that wrongful installation is covered under warranty, especially if it can be fixed by adjusting the screws. But now having seen how yours is, it seems like a simple adjustment and not like it’s bent at all. So that’s good 😕
Thanks! I’ll have to check again but on mine, when I remove those plastic tabs, there is a 3mm Allen bolt no more that a few mm in. Definitely not 4cm. So maybe I’m missing that one. I’ll have to crawl back there and look again. Appreciate the help!
Maybe that’s why 😎
I have allen bolts on a ratchet and they’re about 1cm long but the don’t reach mine at all, the collar touches the back plate of the tv before the allen head is even in.
I don’t know. Maybe ours are constructed differently. When I pop off the cap, there is an obvious Allen bolt, 3mm, right there. Hardy a few mm in. The only way to go deeper is to angle the Allen key to go around the head of said bolt but then you’re going in with a slight angle. Anyways. I’m just gonna have BO come fix it. Hard to say it’s installation error when you pull the cardboard top off and voila, it’s set up. Hopefully they won’t play that card
