I've been having an issue with the new Harmony where it is losing the connection between the screen and the sound centre. It's now happened about 6 times and I've been waiting incase it was something that would work itself out.
It is an intermittent problem. And not sure if it was a result of a software update.
Essentially they are not talking to each other and I've come to the conclusion that it really is operating like a TV with a Stage.
How i know its going to not work is when:
- I click the TV button on the remote which is set to start Foxtel (an external cable TV box) and the screen shows HDMI2 on the side instead of HDMI2 Foxtel as it normally would (the label)
- The BR1 will not have any list functions at all
- The volume up and down will not work
- The B&O remote app on the TV is inoperable and you get the message "unable to connect to your Bang & Olufsen product. Please check that your LAN cable is connected to the TV and try again". You have the option to try again or Disable the B&O app.
- It is connected via LAN and everything is connected by CAT cable.
So i have to when the TV is on:
- Get the LG remote and manually turn off the TV and then back on again
- Note: sometimes that works and today it didn't. I've also done a reset of my network modem / router etc.
I will contact the dealer and they are responsive and great, but I thought if there was a setting that perhaps someone knows if they have experienced the same would save going down an extraneous path.
