After yesterdays
softwareupdate for my Beovision Eclipse soundcenter (software 2.3.xxxx) with
Airplay 2, it has arrived a software bug which is very frustrating.
The software-bug appears as follows:
If you start the Eclipse soundcenter with Deezer (thru the B&O app) or
Music (DLNA-content), the Bang&Olufsen APP loses the contact with the
soundcenter when you switch to another music source. So if You start the TV
with Deezer, everything works perfect. But when you switch to Music (DLNA
content) the B&O-app loses the contact with soundcenter and there is no
cover-art, no time-mark of the song playing and no possibililty to put the
music to "pause". If You after this switch back to Deezer, everything
works perfect.
If You start the soundcenter with Music-source (DLNA-content), everything works
perfect. BUT if you switch to Deezer the same problem occurs as described
before (no coverart, no time-mark, no possibility to pause the music).
If you make a "play-list" in the B&O-app and this playlilst has
content from both Deezer and music (DLNA-content) the first source that is
playing works perfect. When the TV switches to content from DLNA (Music) then
the contact between the soundcenter and B&O-app will not work.
Please forward this complaint to your software-developer and make a fix as soon
as possible. The last software 2.2.xxxxx before the Airplay2-software worked
perfect.
Best Regards
Martin Ström
SWEDEN
Beovision Eclipse - Software bug in latest update (2.3.xx) when swifting audio sources from Deezer to "music" DLNA
I had all kinds of strange issues yesterday after I upgraded. After rebooting my Eclipse and my phone, they seem to have gone away. I haven't played any DNLA sources yet. I will try that later today.
It didn't help that I also upgraded my wifi equipment yesterday...
sorry, duplicate post
I can play Deezer and DNLA, and switch back and forth just fine. I'm using the sound center's DNLA, not the TVs.
How do you create your own playlist in the Beo app?
Speaking of the app, have you noticed the "remote control" capabilities? Including the "touch pad" screen that lets you move the cursor around and select items (similar to LG's "magic remote").
Hi Martin
That doesn't sound good. We will take a look at this ASAP and I'll keep you updated.
Br
Thomas; Bang & Olufsen
Hi Tomas,
I also talked to my dealer in Goethenburg (Sweden) and he also experienced the same fault (softwarebug after latest softwareupdate 2.3.xxx) on his Eclipse in the store.
I would really appreciate if You can make a fix as soon as possible. I use often both Deezer and my DLNA-server (Music-source on the Eclipse) and I change between these sources quite often when I play music with soundcenter.
Have a nice weekend Tomas!.
Best Regards
Martin Ström
SWEDEN
Hi Martin
A small update. We have reproduced the error. Unfortunately this was not covered in our tests, it is now. We will look into a fix and keep you posted.
A nice weekend to you too!
Hi Tomas,
Great! Thanks!
Best Regards
Well done.We will look into a fix and keep you posted. A nice weekend to you too!
Like Stan I would like to know now how one does this !If you make a "play-list" in the B&O-app and this playlilst has content from both Deezer and music (DLNA-content) the first source that is playing works perfect
