beovision eclipse only flashing green light
Hi,It depends on the symptoms. If green light flashing 10-11 secs, stops and flashing again in the same sequence + you can’t switch the tv on + you can’t see any sources from your tv on the remote control, just TV, then it’s the PSU in the Sound Center. If you can operate the tv - maybe with some limitations, it is usually the DSSE board. The symptoms may vary .
How you describe it is accurate, no sources on Beoremote and nothing from the television other than a fast blinking light which is continual.
