It isn't trying to update its software?
Then just wait and don't interrupt.
Thank you for your help!
I tried the Apple remote but it doesn’t work
I tried to reconnect the beo one, but it can’t reconnect
The eclipse runs the whole night with no changes
i checked all connections but not the 2 cable under the tv ( to risky)
I can connect Spotify over chromecast. I see all informations in the app, but the tv is totally dead (no picture and no sound)
I opened a ticket and hope that b&o can support me. I will send a update.
Hi, How did you fix the problem? I'm having same problem
Thank you for sharing
yesterday the B&O Service had change the DSI board from the Eclipse and a something from the LG
Thanks you quick reply. Did they start by give you any guidance on how to fix the problem your self, which I could try?
No, it was very clear. They told me to contact the service partner
My unit has began this symptom overnight and I also had a battery low warning on my BeoRemote 1.
Any update to whether this is an issue that can be resolved without calling out service?
