Beovision Eclipse 65 cracking Noise
HelloAre there other people with the same problem?
To be fair, a lot of devices do this and it depends on your own environment too. The A9 has common creaking noises when it warms up. I've experienced this on my BV11 connected flush to my wall. Become used to the creaking noises now - it's just the plastic expanding/contracting depending on temperature.
That's interesting. I have never once owned a piece of electronics, audio or video, that did that. Nor test equipment. Including tube gear. My toaster makes such noises though, and the refrigerator at times.
First - was that an answer from your B&O dealer (from whom you bought the tv), or was it from B&O direct?
In any case, I think that you should not give up - I’d demand a replacement of the complete tv......if it is more than just ‘a little noice’.
It was the answer from Denmark, transmitted from my local dealer here in Zurich. My dealer was not happy too about the answer.
I am a big B&O fan. I have/had plenty of products.
The Eclipse is marvelleous in performance and design. But what happens now with the noise-issue and the denying of it from B&O
makes me feel not really happy.
I really must think about it. But by that money I spent to the brand after the last 20 years, I really shouldn't give up now....
In the UK one could reject the unit and then demand a replacement or refund.
Thats what I would do.....
Sounds like it was not put back together properly. Something is wrong, a missing washer, screws over tightened and some not tightened enough, something like that. And it's upsetting that on a TV of that cost B&O would just shrug their shoulders and say tough, live with it.
Looks like a faulty installation. Amazing they can walk away from this. Honestly, some people are more sensitive to certain sounds and all active speakers give off some noise from my experience but a ‘cracking’ noise seems unusual to say the least. I think you have a faulty installation.
