Beovision Eclipse 65 and 4K 10 bit
I 7nderstand that the Eclipse can handle 10 bit UHD. Is there a setting to enable this?
I ask because I tried to set it up on sky q but the 10 bit setting didn’t work, only the 8 bit setting
On the setup menu for the corresponding HDMI input on the Eclipse, check if the HDR mode is enabled.
Regards,
Jean
That did it!  Thanks a lot
