I have recently got delivered a new Beovision Eclipse 2nd generation 65-inch (with G1-screen).
I have found two software bugs in the latest software version in the soundcenter:
1. The green light indicator (under the speaker) will sometimes light up even if I use VIDEO-mode (LIVE-TV or HDMI A-D). The green light indicator should only light up when playing music (Deezer/DLNA) in AUDIO-mode. The indicator works fine when playing music in AUDIO-mode but for some reason it also light up sometimes when soundcenter is in VIDEO-mode. This bug is only cosmetic but annoying.
2. The second sw-bug is regarding which sources is showing on the screen when using HDMI-sources:
If I use HDMI B (in my case OPPO-player) and put the TV in standby, and after that starting the TV again with HDMI A (in my case Apple TV 4k) it still says on the screen "Oppo-player" when it should show "Apple TV 4k". Even if the screen in this case show "Oppo-player" the Apple TV source is on and working properly. There is some bug here that makes the soundcenter not show the right source when one HDMI-source is used and after that putting the TV to stand by and after that putting on another HDMI-source. The bug is only cosmetic but annoying.
Have anybody with Harmony or Eclipse 2nd generation this software bugs also?
I hope you understood the explanation above😁
Best Regards
