I've just seen the Connect ID, and talked to the Loewe staff at the french launch event :
It's really a great TV : looks slim but has enough volume to have big sound (high level sound, better than previous Loewe, but still not at the BV8-40 level, which is normal when you see how small the speaker part is compared to the BV8). Image quality is typical Loewe : really good, but I hope there will be no quality problems like on previous sets (panels of largely variable quality where used for the same sets)
Plastic, but good finish, glossy border and soft touch back.
You can choose between 6 speaker+back colors and 3 frame colors at launch, many more later, and you can change colors after purchase (work done by dealer as it's the whole back+speaker cloth that has to be changed).
DVB T+ C tuner integrated, hard disk recorder is optional at 500€ (recording+time shifting is possible on a simple usb key on the entry level). DLNA network player integrated to play movies/music from your NAS/BM5. Compatibility with the iPad app from Loewe : you can read the TV guide on iPad, and choose "watch" or "record" in one touch. Sounds like a perfect "modern technology" link-room TV if you don't want to spend the price of a car for your bedroom TV.
A lot of placement options, some really cool.
5.1 decoder integrated, so you can connect a set of Beolabs without issue.
1390€ for a 32 inch without recorder, add 500€ for the 40", and 500€ more for the 46". And 500€ for the Hard disc recorder. (and no, the remote is not at 500€, it's included 😁)
In short : cool, modern, connected, cheap. It will sell like hot cakes. Hope that the B&O Play TV is on the same level.
