Beovision avant ng
is the beovision avant ng 3d or not?
Not 3D
Same says my dealer, but there is 3d options, and when i tried 3d film avant asked if the 3d mode will be turn on automatic so I am a little bit confused about this one.
Are you sure, that the tv is the NG version?
(There were a few interims versions of the Avant - I am not sure about the details - and differences - there).
I’m sure, there is android, and alsi beotools information is that is ng.
If somebody who has avant ng could tell me if there is settings to 3d watching or not?
And sorry for my bad english, I’m from finland
With respect to the Avant, keep in mind that 3D is only available for 1080P and not 4K. The 4K standard doesn’t support 3D. That said, a lot of media boxes (e.g., Apple TV 4K, Roku, etc.) will automatically scale 1080P content to 4K (regardless if it’s 3D material). I had this issue when trying to use Plex with 1080p 3D material. I didn’t even know my media box was upscaling everything to 4K. I reset the resolution to 1080P and 3D immediately worked. Try setting the output resolution of your media box to 1080P or a setting to match the content resolution (e.g., output 4K as 4K and output 1080P as 1080p). This should solve you issue.
I've sold enough to know that it won't produce 3D.
Yes i know that 3d is not 4k but the question was is avant ng 3d tv or not. And maybe i have to believe is it not. Even the beovision avant ng manual talks about 3d watching...
