Hello folks !
Following the good advices here, I finally went with a BV Avant 75 MKI. I have 2 HDMI source, a Freebox (french ISP set top box) and a Nvidia Shield TV. With my old TV, everything was controlled using CEC HDMI protocol (Loewe Individual Compose from 2009), but I knew I had to go with the PUC system.
During configuration we realize that the Freebox isn't IR driven (radio) and the Shield is BT :). I order everything needed to have them worked with IR (and attached the IR PUC on them), but I wanted to have some feedback from people about it. The 2 source are listed on the PUC list, so I assume everyhting will work straight away once plugged and setup, but I suspect it could not be so simple...
Any feedback ?
One more thing... Are there any advices on the parameters to use on the TV ?
Cheers,
Serge
