I've purchased a second hand BeoVision Avant 55. It was delivered via a BEO store for myself to set up. Looking for advice please on how to remove transit brackets as I've no idea how they come off!!
Brackets/supports as photo.
Pull straight down. Use a bit of force. That should do it.
And don’t forget to remove the two screws for tightening up the speaker box.....if they are there (which is not always the case).
Thanks Champbeo, I'll give it a go when it's on the stand. Just waiting on a power lead!
Thanks MM, they're not there! Hope speakers will still be ok!
I was utterly flummoxed by this too, and disassembled some of the housing on the TV to figure it out; and failed. As champ said, yank them down hard.
