BeoVision Avant 55 or BV 7-55
I need help and opinions deciding between these two BVs.
New to the BV offerings but I do have a BV 7-40 which is great.
Needing a larger screen I’m considering the 7-55 as from what I’ve read it’s up there with the best B&O has made.
However an Avant 55 mk1 is younger and offers easier integration to future additions.
Can anyone offer any help choosing or experiences you can share with these would be amazing
I have an Avant 55 First Gen, and I completely love it. I bought it for two primary reasons: plays 3D blur ays, and the amazing two motion floor stand. I bought it from a dealer second hand, which I highly recommend.
-Gregg
Thanks - that’s one vote for the Avant 55 😀
Make it two.
I’m with Gregg, very happy with my Avant 55.
I don’t know the Avant MK1, but I have the 7-55 and for sure the picture quality is better than the BV11-55 I also own. Last week I read an article shared by someone on this forum that was rating the 7-55 as best B&O TV ever. The Avant MK1 was in good position too if I remember well.
Daniel wrote:
Make it two.
Make it three.
However, if you don’t need NL integration and the advanced audio option of the BSys4-engine and more......,you’ll be happy with the BV7-55.
I edit myself as I found the article about ranking. The Avant 75 is in it, not the 55.
here it is:
Thanks - I did read that and that’s why I was considering the older BV 7-55.
Its not as expandable as the newer models but it sounds like the pinnacle of BV 7s is a hard act to follow!
l haven’t measured the space up as yet but I believe the BV 7-55 is pretty big and maybe too large for the corner I’m try to fill
As far as I know the BV7 is based on the Beosystem 3 platform, the Avant on more or less the Beosystem 4 type of sound engine.
Owning a BS3 for may years which I now have retired the sound quality at multi channel audio does not come close to the newer systems.
At least at my market there is still a big gap in budget for both superb TV sets which does not make it easy..but I would go for he Avant as also retired ML and switched to NL.
Great advice thank you.
I agree the Avant helps me create a better pathway forwards.
do you think version 1 or 2 of the Avant 55?
Researching this I’ve heard v1 was a better offering
