Beovision Avant 55 mk1 screen fault
Hi, my beovisuon avant- screen has suddenly stopped working. It just shows a purpley distorted screen. Menus don’t come up. Does any one know what I can do about this? I have tried turning off and on but that does not work. I can not access the menus to do any kind of reset.
thanks!
This could be DVE, can you take a picture of this fault?
That’s the Digital Video Engine fault, has to be replaced. Contact your local dealer and report the problem.
The remedy will be,- buy an Eclipse
So my Acant has now been repaired and. Is in full working order. The issue was with the graphics chip or something. Even though the TV was 6 months out of warranty the b and o store in Russell Street Melbourne organised it to be picked up and had it repaired free of charge. I seldom post, but i just wanted to highlight this excellent service.
Thanks for doing so, we definitely need these stories as well. I am happy that it worked out so well for you!
Did you get a confirmation that this was the video engine that needed to be replaced? Or other work description?
I have the exact same issue, problem is little older than yours, so I am certain there will be no warranty exchange.
My Beovision Avant 55 has the exact same problem.  I have been advised it’s the Video Engine board!! Did you have yours repaired?
Just had mine replaced as well  its a very expensive fix and B&O had a significant back order- so quite a common  problem
I wonder if the NG is more reliable?
