Beovision Avant 32 DVD and PS3
Hi all,
I am a new user of the forum and have just bought a PS3.
how do I connect the PS3 to the beovision 32 DVD unit that I own. Currently, i have a scart into the decoder input.. giving nothing.
please help... thanks in advance
bhav
Is the Decoder scart socket set in the menuon the Avant?? If it is and you are sure that you have chosen the right "channel" on the Avant, then turn on the PS3 by pressing and holding the on/off button until it beeps a second time.
It might be because the PS3 is set to use the HDMI output and when you do as described above you force it to change the setup.
