Beovision & PUK codes
I have the Beovision 11. Just connected my samsung bd-c6900 blue ray player and tried to get the beoremote 4 to control it but I can't find a PUK. I think i've downloaded the latest codes and did an internet search via the TV.
Is there another way of getting the code? There is an option to add it from a usb. Can i find more codes searching on my PC and transfer it to the TV by USB?
thanks
thanks
Try if you can find something similar to the Samsung you have, in the PUK list in the BV11. Think Samsung are very generic when it comes to remote codes, so another PUC could work.
