Hello,
As above... I can't get stand to work... Is there a plug/connector? If so does anybody know where it is connected to.
Rgds
Hello,
Rgds
Connector on the base goes via cable to inside the BS3. Sometimes the small wires can break at the connector at the base-side.
Many thanks.... Now I have a clue where to look.
wires are very fragile, or the TV has spun too far manually and popped out of the mechanism to rotate
