Beovision 9000 problem - can any anyone please help?
Hi to all B & O enthusiasts,
When I attempt to start the Beovision 9000 it shows the message SW.1.10 error 1 on the lower display panel. Does anyone know what this means? Trip to the technician, expensive repair or graveyard maybe? If it is the graveyard, I would gladly donate to anyone who could use the parts. I would really like to keep it going though as it is a beautiful design.
Thanks in advance for any help.
anodyne1.
Many thanks for the good wishes!!
Where are you based? It can sometimes help should we need to recommend a helping person! Would hate to see a 9000 binned! Always fancy a 9002 some day!
I am in Geneva, Switzerland.
You get this error when there is no communication between TV and ControlCenter ( stand ).
If the TV doesn't power up the problem is there.( Red led on top of TV should be on in st-by )
If TV powers up the problem can bee blocked MasterLink. Try a good ML-cable between TV and ControlCenter to check communication between them. If this helps then the problem is somewhere else in the ML.
 Graveyard is not an option for any B&O.  :)
Moritz
