Beovision 9 + Xbox One = PUC Problem?
I would like to control my Xbox One connected to a Beovision 9 with a Beolink 4 using PUC and IR.
Unfortunately I can't get it to work, therefore three questions:
- The PUC selection in the Beovision 9 menu is called "Microsoft Xbox" is this the correct PUC entry for a Xbox One?
- Where exactly is the IR receiver at the Xbox One?
- Do I have to enable/disable anything in the Xbox One menu?
I am thankful for every hint / help
No, that's for the original xbox. You'll need an engineer visit to install new PUC tables on a BV9.
From memory, it's near the eject button.
No, it should just work once you have the correct PUC installed.
Martin.
Alternatively, you can use a Flirc USB (a small universal infrared-receiver USB dongle) on the Xbox One. Then you can select any device from the PUC list of the Beovision 9 and teach it to the Flirc accordingly.
Might be a little cheaper and more flexible than having a B&O technician come to update the PUC list.
