Beovision 9 type 9721
Hi Can anyone advise what year and mk......mk1,mk2,mk3?Rgds
9721 is a mk2 (06/2007 to 05/2008)
Thanks......but decided against it ...screen was a bit suspect Login to view imageNo a great photo but you can see the lines that are appearing every time you switch on.
Same TV with the 'WAIT' problem, or was that a different TV?
Graham
Same, managed to get master pin code which worked no issues, but screen had these lines on it, Unplugged data plug to bs3 and it cleared but came back when you turn off and back on...so I assume panel on its way out!
