Hello all
I have the above setup and it works fine, with a couple of exceptions.
I cannot find the correct button(s) on my beo4 that produce the same as pressing the opt+ button on my humax remote handset. I can't use the humax remote as the box is hidden away.
Does anyone have a button map cross reference for beo4 and this stb?
i'm aware not all functions may be supported but this particular button is part of record delete so I'm hoping there is a solution.
many thanks
