BeoVision 8 Tuner
Hi there guys;
how are you?
I was just looking at buying a BeoVision 8 26" for my bedroom, however i really dont want to buy it if i doesnt come with a High Definition tuner, whilst its been called a HDTV for some reason, im doubting the fact it has a HD tuner. If not, is it available as an inbuilt option or not? And how much would such an option be.
Sorry, i'd like to just add/edit that rather then having to have a HD tuner, i will want a digital tuner.
You are right, You should not buy a tv without a DVB-T tuner, as analog is going to be turned off soon.
HD however is not necessary on a small screen like a BV8-26
