Beovision 8 experience, does anyone here own one?
There are few that have it. I am happy with mine. Was a bit of a compromise, I would have preferred BC6 or BV7 32 - not available in the US and the chassis are a bit outdated on both (one HDMI is not a lot but still better then one DVI buddies).
Just watch out that you get everything that you need connected.
I have BC2, Apple TV, a Wii and left the component port open for future cable TV tuner ....
Cheers
JK
You don't want to hear about my BV8-26 experience. I don't think I'm 'allowed' to post the details here. I'm still waiting for B&O to come back to me with some answers about why the experience was so poor. Still waiting.
However, I can tell you the picture was better than I expected, even though I'm used to a HD source on my BV7-40. Sound was very good, but a little 'boomy' for me. I turned the bass right now.
BV8 is a fantastic good TV. Have a great sound and a nice picture. But why is there no clock, and why it is not possible to connect a module for suroundsound in BV8?
I have connect BL8000, Apple TV, DVD, STB to my BV8
Edde
http://forum.beoworld.org/forums/storage/20/94964/IMG00250.jpg
picture is here .... it was right after I got it so the cables were not hidden .... now they are and I added the Wii and an Apple TV.
Actuallly I think it is perfectly fine Moxxey if you post what went wrong. I think for some it works out well, for some not. SHould be OK to post both sites since this is an independent forum.
Billywicks,
I have one (a BV8 32") that I have hooked up to a DVR / HD cable box as well as an Apple TV. jk1002, Soundcheck, Alex, and others helped me hook it up. I'm very pleased with the BV8's PQ. I'm an Apple nut, and I'm gradually matriculating to only using an Apple TV with high speed internet (and getting rid of my cable and cable box). I've had the oppurtunity to see a lot plasma and LCD screens in use, and I'm really happy with the BV8. I'm using a BV8 with BL3s connected to an Apple TV for most of music and video playback and I think it the ideal "minimalistic" set-up. The DAC in the BV8 is sufficient to give good sound through the BL3s and my experiment in making a "digital hub" sans receiver / amp / etc. has worked. When a bigger BV7 comes out, I'm going to buy one from Alex and put the BV8 in the bedroom.
Incidentally, the BV8's speakers are what really separate it from the competition. Also, though it has an older Sharp LCD panel in it (supposedly with a slower flicker rate), I've been incredibly impressed with the "film-like" quality of the images (even non-HD), and I've never experienced any artifacts with motion in action films.
Just my .02,
MarkD
