Hello, thanks so much for coming back with more suggestions. To add a little more context, I've moved house recently. Before I moved, I had another Beovision 8 which I don't have space for here, and that did have different menus to this one (probably the ones Keith is referencing). On this model, if I go into the TV setup menu there is no OPTIONS option.
Guy asked if I used the Beo4 to control the Sky Q box, and the answer is that I don't on this television. I've got a Beovision 10 in the living room, which I do use that way. If it's of interest to anyone else, I managed to get the Beo4 to control the Sky Q box by using the KIRAQ Ctrl4Sky device which takes the IR signals output to a Sky+ box from the PUC controller from the Beovision 10 and converts these into network commands which can control the Sky Q box. This gets around the problem that the Beovision PUC outputs IR commands but the Sky Q box uses Bluetooth. I might consider buying another KIEAQ box for my Beovision 8 if I can get it all setup how I'd like.
I've tried Guy's suggestion and I can make the box so it is activated by the DVD button, which is an improvement over V.AUX. I think this would probably stop me using the Sky PUC though.
Thanks for your suggestion too, madskp, I've checked the menus and I don't have the INPUTS option where it suggests it is in the DVB guide. The DVB can only work with Freeview, I think, so perhaps it is a UK specific version with more limited options. The guide also makes reference to being able to perform a software update using a USB port, and I can't find that on the back of the TV either.
Looking in the DTV menu, the Freeview module reports the following information:
Release: 4 Feb 2010
Version 0.2.1.6
Model 0.5.0.0
Looking on the service menu, the TV itself reports this information:
Type No. 9550
Serial No. 20430157
System Module 32.30z
DVF FEP 02.20a
DVB Module 02.16
There is some other information in there, which I can provide if it would be helpful but those seem to be the most relevant points.
In the CONNECTIONS menu, I have AV1 through to AV4 but none of them allow the selection of DTV.
I've managed to transport and install all my B&O things from my old house, and this is the one thing that has beaten me! In my old house the TV was connected to a TV aerial and used Freeview, but in this one there is no TV aerial to connect to anyway.
I've searched on the Internet a bit more, and I think that this might be the module that is installed - the menu listing match mine, but there is no option to disable that I can seeL
