BeoVision 8-40 VGA-input through masterlink to MX4002 ?
Hi everyone,
I have a question about the VGA input on the BeoVision 8-40. I'm thinking about buying a new MacMini to replace my older one as the mediacenter in my setup. And then I got to thinking, that 'maybe' I can use the old Mini as a mediacenter for masterlinked televisions!?
Here is my question: Will I be able to distribute video to my other masterlinked tv's if I use the VGA input on the BeoVision 8-40?? VGA is analog, isn't it??
Regards
Claus
http://www.cypeurope.com/Synergy/SY-M388-HDMI-Down-Scaler.html
If you can have hdmi from your mini, try one of these. It will send hdmi and composite to the main tv. The tv then can modulate the composite and send it around your aerial system.
