Beovision 8-40 - remote control setting issues
I bought a preowned bv 8-40. It seems like it is configured to work with beo4 joystick version since I can use the arrow keys on my non-joystick version. Can I reset the TV some way to change this setting?
Many thanks!
No reset needed.
Just call up the menu and navigate using the numbers - means 1 for the first, 2 for the second.
Don’t forget to accept with Go.
Oh, of course I should have added, that you will have to navigate this way to the Beo4 setup item...
.....where you can change the behaviour of controlling from with to without navi.
This one
Super, it worked!
Thanks!
Super, it worked!
Thanks!
Super, it worked!
Thanks!
