I bought before some days a beovision 8-40 and today i found a problem . In football games there is a small delay in the movement of the ball and the players ( like slow motion). The game was live from satellite tv.
beovision 8-40 problem
Hi vamvakar,
Congrats on the new tv. Try turning off "FILM MODE" in adjustments. Maybe it will help!? Don't know, but maybe. 🙂
The menu can be accessed by pressing the menu button twice. Then RED + GO while the cursor is placed on the CONNECTIONS field. Then "Adjustments" and FILM MODE OFF...
Hope it will help. I think the TV becomes much better with FILM MODE OFF!!!
Thanks for your answer. Its better but not perfect. Maybe its the resolution or something about 100Hz . Can anyone help me?
have you tried resetting / rebooting your digital setup box ? or perhaps rechecking the digital output from the box to the tv.
i did that for my 8-40 and it worked. personally i kinda like the film mode on.
I don't think this is the TV. Sounds more like the digital box or DVB-T. Delays are usually a transmission problem or a decoding issue. Have you tried a different satellite decoder?
