A simple SW update should make everything work properly.
I think they would charge less. Where in DK are you located ?
maybe you know someone who can help?
I had a similar issue (Build number red) but ML works.
I wrote to Beocare and they told me, the build always has special sofware for the SM included, there is a mismtach, but the SM should work in daily situation, whatever this meant :-)
The actual SM SW is 50.x. for Build 229. If I am right the 166d and 20.05 should work together. The SM Modul SW entry could be red as well, even in that case it should work.
What error do you have? There are many configuration options and you shold always unplug your whole ML system from mains for 30 seconds, then install all cables and plug everything back to mains. The LED on your BV turns green for 10 seconds and checks for other ML equipment.
Give B&O a try, ask them for a update, i carried my BV8-40 to the local Beostore in Hamburg and could wait for the update. It took only 15 Minutes and was 25 Euros.
Ralf
PS. You should update the HD Software to 0.1.9.9 this could be done by yourself: Download from B&O and put it on a USB Stick.
could i know where you got the masterlink module ?
I'm looking for one too.
Zazou
