Beovision 8-40 Masterlink module?
I think your bigger problem is finding a Masterlink module to buy..
However, if you do find one the diagram below should help
If there is no software update to do on a non-masterlink BV8, I've got a spare module almost brand new... (just tested that it worked the same that my current module, and sadly, the faulty thing in my BV8 is not this module). But I suspect high shipping cost from France
No, these aren't the same modules. Maybe the BV10-40 module is the same as the BV8-40.
BV8 40 and BV10 40 MK1 and 10 46 MK1 use the same ML PCB but the metal frame that the PCB is mounted in are not identical.
Now I got a masterlink module for 28 euro, called system board. I got it in a few days. Then it is just to plug it in?
