Hi guys,
I have a question regarding my BeoVision 8-40. I have the version with 100/120 hz refresh rate.
Does the television itself change from 100 hz to 120 hz, when I choose between PAL and NTSC on my MacMini ? Or is it the 'FILM MODE' which changes the television the 120 hz ?
BeoVision 8-40 hz question
The film mode senses automatically the incoming signal trough the HDMI port, but only if the source allows it, that means that your MacMini needs to support 24p output to be able to make use this feature.
