Beovision 8-40 broken feets.
I have just bought a BV8 with the elegant tiltable feets. But both of them have cracked due to tension, I think. It looks like the feet themselves are doing fine, but the brackets, mounted to the TV are bended.
Does anybody have a fix for that? Or would it even be possible for me to be lucky enough to sort a spare part? πŸ™‚
As I see this is a quite common issue.. πŸ˜›
And as I see the BV8-40 doesn’t share the same feet as the B8-26 and BV8-32.
Stbbrackets.com have replacement. But not cheap.
Hi Esax.
i saw that, and found that a tad too expensive for replacements that isn't adjustable like the original items πŸ€” ..
BTW.
Does anybody know if it's possible to dismantle the original feet / table stand?
As i recall, the only difference, from the feet of the 8-40 and the feet of the 8-26/8-32 is the feet themselves. The sliding bracket, should be the same??
If it's possible to dismantle the feets, i could search for the parts from the 8-26/8-32 and clone them together, as the broken parts on mine, is the brackets πŸ˜‚
