Beovision 8 32"
I'm thinking of purchasing a beovision 8 and have heard rumours that it will soon be available in 32", can anyone confirm this?? also has anybody seen a beovision 8 in action. My dad has a beovision 7 and I hooked up my ps3 to it and was blown away by the quality and sharpness of the image I was seeing, I mean I played the same game on my mates top of the range Sony and whilst the picture was good the B&O picture had more detail and was sharper, can anybody explain this, is it down to the video processing the B&O does??
Do you think the beovision 8 will produce as good a picture as the beovision 7??
Yes - it's true!
I doubt the image will be quite as good as the 7, but the price will be just over half that of the BeoVision 7 screen if sources are correct.
Lee
Hi dbitalia! Was it BV 7-32 or 40"?
I have seen Beovision 8 and can just say that Beovision 6 are much sharper and have not so blurry picture as BV 8...
I should go for the Bv7 32" if i were you...
Regards
I personally feel the upscaling is better on the BeoVision 8, and overall, the picture is better than on the BeoVision 7 when you consider price! I would wait for the BeoVision 7 to be updated, as personally, I think it performs under-par at present.
Yea my dad has the BV7-40 HD
I have heared when using the DVI input for hd material on bv7  it does not run the image thru the B&O image processor, its basically outputting directly from the source, is this the case??
