Question beovision 8-26, I have virgin v6 box going round the one of the freeview channels and works fine on the other bang and olufsen tvs. However on the bvis 8-26, i have perfect sound but no picture, tv has has been updated to latest software and the freeview module has been upgraded. Has anyone has this issue?
Beovision 8-32 freeview
Hi, thanks for the reply I never thought of that will give it a try
I had the software updated and changed the resolution to 720p, still no picture but perfect sound, all the other tv are working, I have put a cheap freeview box in and I get sound and picture, worst case i can put this in back of tv, any ideas why built in freeview wont work, both software on tv and freeviee have been updated
Where did you change the resolution to 720p?On the Virgin V6 box? On the cheap freeview box? Other device?I had the software updated and changed the resolution to 720p
How did you connect the cheap freeview box to the BV8?HDMI? SCART? Other?I have put a cheap freeview box in and I get sound and picture
In your BV8’s TV TUNER menu, is TV TUNER set to ON and/or is DVB HD set to ON? (See page 24 of the User Guide).(a) My recollection is that the TV TUNER is for analog transmissions only, not freeview; it is selected with the TV button.(b) If you have had the DVB HD feature updated, you should select that with the DTV button (unless that button has been re-assigned to another source).(c) Is your DVB HD module connected internally to the TV, or does it have an external HDMI plug that needs to be plugged in to one of the BV8’s HDMI sockets (like my BeoSystem 3)?any ideas why built in freeview wont work, both software on tv and freeviee have been updated
Hi in answer to your question
Tv has been updated to latest software as has the freeview module. I don't use the hdmi as freeview is internal which i select with dtv, freeview is working. We have an hdmi modulator that is connected to the virgin, which allows me to tune in virgin to the freeview, this works on all tvs except the bvis 8-26. I can get sound but no picture. I did try and put the resolution down to 720p on virgin box but same issue
Hey thanks for the reply, it simply allows yoirnto distribute hdmi via a freeview channel, i seeing it allows 720p output failing that thits freeview box on the back of the tv
