Beovision 7 STB controller Virgin TiVo box? STB
Hi do any of you guys know if my STB controller will work a TiVo box? Thinking of moving to Virgin, monitor information says
STB table 3.6
type 9324
TiVo M6500A HD is supported in the latest version 4.45 (Western Europe) Table.
You will need to get an updated chip for your STB-C
Look
Does my STB work any of the Virgin boxes? And do you know where I could buy the upgrade?
I mis-read your posting and focused on the STB, but the BeoVision 7 has a PUC NOT a STB-C which is software up loadable.
Check
