Beovision 7 MK5 flickering image with Apple Tv but ok with other hdmi devices
I am new to B&O as a owner, although my parents always had B&O devices.
Recently I have purchased from an hotel, a BeoVision 7 Model 9184 with 2 HDMI ports.
The HDMI works ok with some external drives that can stream divx, but using the same cable (HDMI) on Apple TV 3.
So far I have try:
1. Changing resolution on Apple TV video settings (720p, 1080, Auto, and all the others)
2. Using a different cable.
3. Trying a different HDMI port on Beovision
4. Called the B&O support, to ask if this was a normal thing. Or if a software update was needed.
Can anyone help?
Many thanks
 Mauro
Did you try this:
Select the resolution to a lower frequency refrsh. Eg if it is at 1080i 60hz put it back to 1080i 50hz from audio video settings in apple TV.
I am sure it is a setting issue.
720p 50 Hz is what I would try first.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I have try to all the possible video setting on the apple tv.
