Hello
OK the type is 9459 and First four digits of the serial are 2144 which i believe is a MK3 ?
Hello
It's a 7-40 TV (w/o DVD/BD built in)
- chassis similar to Mk3 types
- to get AST the DSM module has to be exchanged to new type DSM MK 2.5 fΓΌr BeoVision 7
ask your dealer/service center
ok next question
was the MK4 without DVD / B Ray ever 100Hz or was it always 50Hz??
Hello All
All sorted!
Bit of a silly mistake by a dealer.
MK4 on its way.
Thanks for all your help!!!
Good job you didn't change the notes at the bottom of your posts about having a BV7 Mk III then!!!
ok next question
History - as far as I remember π just beeing 93% sure *g* :
- The "special model" BV 7-40 TV never got a later version than the Mk3 = 50/60 Hz chassis.
- At approx. the time of introducing BD (summer 2009) the "special model" BV 7-40 TV was discontinued.
- The built in DVD/BD became an optional feature
- there should be 7-40 Mk4s with 100/120Hz w/o DVD/BD
(been produced in the 2nd half of the year 2009 and 1st half of the year 2010)
- 7-40 Mk5 200/240 Hz was introduced mid 2010
Def have MK4 now.
100/120Hz showing in panel info.
one thing i cannot set is masterlink delay as its still grayed out
i have the dst 2.5 according to the hidden menu and software 9.01
cannot find AST to switch it on.
Help Pls
You'll find the "switch" for AST in the sound-menue of a 7-40 Mk5 /SW 8.12
selecting menue > options > sound > AST ON/OFF
? maybe a Mk4 / SW 9.01 is different ?
yeah its 100% not there.
there is another thread about this in here so it might be a problem with 9.01 but i cannot adjust my masterlink delay.
edit: If the ML is grayed out and you have DSM module 2.0 or higher AST needs to be in the menu but does not have to be switched on just present.
If AST does not appear then the DSM FEP and DSM DSP software are to old
This is seperate from the H8 Software we normally talk about.
My TV has 9.01 but the DSM module sw is 4.23a and 4.19 which is to old for AST to be shown.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
