Does anybody know if I can fit a DVB HD module to a Mk3 BeoVision7? My local dealer is telling me it will not work.
Thanks, Andrew.
Thanks, Andrew.
Anybody have any ideas?
Did he tell you why it should not work?
I don't see why not.
Maybe you should try asking another dealer (who has a technician in his staff).
If you are talking about BV7-40 MK III - the first Beosystem 3 based BV7 - tell your dealer, that it will work...🙂
Stefan
Ah sorry, no I'm talking about the BV7-32
Ok.
Sorry, no clue..
Stefan
Well - if the 7-32 already has a scaler built in (I am not quite sure if they were born with the scaler) and you can get a HD module, that should be possible.
There are some threads about this question on the forum - and were on the archived forum.
I can confirm that a DVB-HD module Type 4783 can be fitted to a mark 3 & 4 BeoVision 7-32
Type 4772 is available for BeoVision 7-32 mark 5
Perfect, and that unit will pick up UK Freeview HD? B&O are saying maybe not.
