BeoVision 7 MK2 Mutliple HD Sources
Hi Guys
We have a BeoVision 7 MK2 which has only one DVI input connected to a SKY HD box via a DVI to HDMI cable and a scart for teh audio. The issue i have is that i would like to connect up either an Apple TV or alternate HD box.
Is there a device available  (B&O or third party) that will allow me to connect multiple HD boxes to the TV?
It depends on the software level of your BV7. If it's 7.94 and upwards you get the ability to use the HDMI expander function, which let's you assign HDMI-1/2/3/4 to the DVI port. Now you can use either a Gefen HDMI expander (the most expensive solution) or a simple HDMI switcher like
Oh, welcome to Beoworld Beo_Vision 🙂
You can hdmi->dvi+rca converter.
And connect a hdmi expander before the converter.
Thanks Guys, how do i check which version of the software we are running?
On your remote press MENU 0 0 GO then Monitor Information.
http://www.hdfury2.eu/hdfury-2.html
would this work to the component inputs?
I checked today and the panel is running 7.84, obviously I want the best possible solution that will give me the most options and flexibility. Do you recommend I get the software updated and then purchase an expander? Are there anyone benefits going with gefen expander instead of a basic hdmi switcher?
The gefen switch can be controlled via puc with beo4.
I did it with mine when I had it, and it was a lot of money out the window just to be able to use the remote.
How many hdmi sources are you connecting?
Get a switch with auto-switch.
At the minute 3, out if interest how much is the gefen ?
