I would like to clean the inside screen of my beovision 7
Which product can I use ?
Any help or advise welcome
Ken
Ken
About the only thing that won't cause streaks when wiping the anti-glare screen is the steam from your own breath and a very clean microfiber cloth. If your screen is really dirty, this can take a long time.
I once had a girlfriend who saw no buttons on my TV and assumed the screen was touch sensitive like an iPad. I must have spent several hours cleaning her fingerprints off my BV7-55 screen. What a mess!
Thanks for the reply Hungedu, but I have a problem with dust on the INSIDE of the screen.
I guess I have to take the TV to bits to get at the inside of the screen, but wont to know how to clean it so I dont get any marks.
Ken
Take off the backpanel. Then at both sides you will see screws with a spring. Unscrew these. Then lift the glaspanel for a centimeter and take it towards yourself.
With the mk1 and 2 you have screws on the left and right side.
The best thing to clean the screen itself in window/glass cleaner in my experience. Also try removing the screen like others have suggested, it worked for me.
A damp cloth (water, plus a little dish detergent) works well too, but you need a dry cloth to hand (or several dry cloths).
Wipe with the damp cloth first, then quickly buff with the dry cloth. I find it easiest to clean a small area at a time.
The water in my area is very soft, so this may not work so well if you have a lot of dissolved minerals in your water.
