Once you connect the scart cable, and the Firestick you need to go into the TV connections menu to tell the TV that when you press the V.MEM button to go to that input. The Scart inputs are usually numbered something like AV1, AV2 etc
So whichever AV input it is connected to (eg AV2), choose V.MEM from the list for that input. The menu should look a bit like this
AV1 DTV
AV2 NONE
AV3 NONE
AV4 NONE
CAMERA NONE
PROJECTOR NONE
And you change what it says beside the input to the button you want
AV1 DTV
AV2 V.MEM
AV3 NONE
AV4 NONE
CAMERA NONE
PROJECTOR NONE
When you press the V.MEM now, it should go to that input and show the Firestick. if it is pluggd into AV2
With B&O you do not use the numbers buttons for any inputs, but rather you allocate a specific button to it. So if you have your DVD plugged into AV1, you go into the menu and assign the DVD button to AV1. If you do not have a DVD connected to AV1 and plug your Firestick into AV1 you can still allocate the DVD button so when you press DVD the Firestick shows, or if you prefer to press V.MEM, then alloctae the V.MEM button.
Be careful not to change the setting for the Sat Box AV input or that will stop working. It might be an idea to take a photo of the settings before you change any so you can put them back if anything goes wrong.
Stoobie
