Beovision 7 and PUC
lost the manual for BV7. How do you set up PUC for Opportunity 103?
I assume you mean the Oppo 103? Using the Beo 4, press menu to bring up the BV 7 menu, then select options, then select connections, then select the input you have it connected to, then press the center button to store, then the list of pucs available in your BV7 will appear. Select the puc you want. If you do not have the correct puc, you will need a service call to add it.
