HI! I've got a beovision 7 tv and even is little old I love it, i'm planning to connect to it a apple TV a chromecast or a laptop using the dvi input , i've tried with the computer , the computer and a hdmi to dvi cable and even the laptop detects de screen , I'm not able to select the dvi input of the tv , i've read the manual , and as i understood i have to select the av1 option to pc and then says use the list button and select pc, unfortunately the lcd screen of the remote is broken and i cannot see anything ,i 've tried "blindly" to push the list one time and ok , two time list and ok and etctera but i'm not able to put that pc input , there is someone with a beovision that can help me ? I'm doing it correctly ? If my idea is correct , could someone explain me how many pushes hay need to do in the remote ? Like two times , list , then right then ok.... alternatively there is any method to assign some of the remote buttons to the pc input ?
Thanks!!
