Beovision 7-55 - what spec / Mk?
Hi all, Can anyone help identify what spec and mark the following Beovision 7-55 is, please?
Type: 9483 (market = UK?)
Item: 1846457
Serial: 22245618
Is it backlit, does it have an HD decoder and does it have a DVD fitted? I’ve found this on the second hand market and want to check it’s a good deal.
Hi
The type number 9483 is for these regions: Botswana, Ireland, South Africa, United Kingdom
DVI or HDMI:
  • DVI and HDMI
DVB-T, S, C or analogue:
  • DVB-C MPEG 4
DVD, Blu-ray or 3D Blu-ray:
  • DVD
  • Blu-ray (optional) So check if it has the Blu-ray drive installed.
MK 1 or 2:
  • MK 1
The 22 in the serial number could indicate that it might be from 2010. Around that time.
Thank you, Champbeo.
is the DVD a standard item, or would it have been an optional extra and therefore no way of knowing if it’s fitting without seeing the set? Thank you.
Blu-ray/dvd was option and there was no dvi.
