Beovision 7-55 - Apple TV
Hello,
after fixing the majority of issues with my newly acquired TV,  there is one left.
I use my  shortly purchased 7-55 mk1 with technisat Receiver and Apple TV 3rd Gen. All controlled via Beo4.
2times already in 4 weeks, there is an issue, that After changing from DTV to Apple TV and watching YouTube, the System locks up and does not accept any command of the Beo4.  Neither on/off, nor louder or anything else. Only way to move fortwarf is, to pull the Plug and restart.
is this a Common/ known issue? Any fix?
thanks,
markus
I have not experienced anything like that with my BV7 and Apple TV.
I have used mine with apple tv 3, 4 and now 4k. Never had any problems. But I do not use puc.
Will probably try other PUC socket next time. So far only appeared with Apple TV, not with receiver!
very odd.
thanks for your Reply anyhow!
very odd.
