Beovision 7-40 no picture with PS4, but picture with ATV3
I have had my PS4 connected to my BV7-40 mk2, and had no problems with it.
Today I did a reset of the BV7, since I had some issues with speakers.
Now I cannot get a picture from the PS4 anymore. If I connect my ATV3 I get picture without a problem. I even took the PS4 to my neighbour to set it to 720, but still no luck.
Any suggestions? I think it is very strange that it doesnt accept the PS4 when it accepts the ATV3.
THe settings are DTV-A1 (dvi-input). Even tried with v.mem, but still no luck.
Had the same problem with a PS3 and a BV7-40 MK2.
Everything worked fine until that one day when I did a factory reset.
All other devices (ATV2 + STB) connected via a HDMI switch worked flawlessly. Only the PS3 never showed a picture on that TV again.
I tried at least 5 different HDMI cables with different DVI adaptors with and without the HDMI switch. No chance.
On all other TVs the PS3 worked without any problems.
Curious whether there are others with the same problem and maybe a solution...
Might be a corrupted EDID EEPROM. But why is the ATV working...?
BR,
BeoMotion.
And you never got it working again? 😉
Maybe I should try putting my germ hdmi expander between the systems.
But I was so happy I got rid of it.
Handshake problems!
Plug it out/in a couple of times. Turn of/onthe power of the tv. Plug it out/in again.
Might some times help.
In my case I really tried everything. Plugging in/out very often in different states of the devices. TV on / PS off / PS powercycle / TV powercycle / PS on. In a lot of combinations. Nothing helped.
I also resetted the PS3 several times and tried a special "resolution savemode".
No chance. Never got it working again on that TV! :-(
I got picture a couple of time. But now it is not coming back.
I my case this didn't work either.
If I remember right this was the same case with my BV7.
I really hope that you are able to find a solution for your setup.
HDCP error?
Check customer service menu -> adjustment -> HDTV -> HDMI.
V/ Mikkel
MCB wrote:
HDCP error?
Tried both, HDMI and DVI mode. Nothing worked.
