Beovision 7-40 MKIII service manual
I have looked but I can seem to find the Service Manual for Beovision 7-40 MKIII. Is it not on the site or do I need to upgrade membership?
/Lars
What type number is yours? I'll have a look around tonight. You are silver already so you don't need to upgrade.
Thank you. It's type 9376.
All I really need is to see how I install the DVB-S/T module so it may not even be the service manual. It is just my guess.
/Lars
Lars,
The installation instructions for the DVB-S/T module are NOT in the Beovision 7-40 Service Manual
It has its own installation Manual, but even if you have the manual and install the DVB-S/T without problems you will need to get your dealer to update the Beovision with the Service Tool.
I'll put the guide on anyway.
Keith Saunders wrote:
Lars,
Thanks for that Keith. I will call him next week and see what he can do.
What will need to be updated?
/Lars
Thank you Peter. Very much.
/Lars
Very straight forward job. Just until it says "Flashupdate product, using the Bang & Olufsen ServiceTool"😎
