Hello all,
Newbie here, have come across Beoworld and boy am I glad I've found it! Have recently acquired a Beovision 7-40 Mk3 and am left scratching my head at some things as the support documentation is honestly a little "idiosyncratic" if I'm honest ;)
I have the motorised table stand and the 7.2 speaker also. Boy oh boy is that speaker fantastic, hands down the best feature of the package by miles. Here are a few questions, apologies if there is an exact answer pre-existing, I've done by best to find it!
- The motorised table stand: I can't seem to get things to work as expected. In short:
It doesn't turn side to side at all. Could of course be motor failure, no red lights under the TV to suggest software failure. Stand is recognised by the TV in menu so connection seems fine, no obvious fraying of wires. In the stand orientation setup, I *can* tilt up and down by pressing green/red on the Beo 4, but no turning using the left/right buttons. When pressing stand on the remote I can't seem to get anything to move at all. Preset video/audio/standby stuff, can't seem to get anything to move (neither turn nor tilt). I wonder if it's an issue with the remote - I know there are some peculiarities depending on the model. My model has TV/DVD/RADIO/CD/AUX on it.
- HDMI looks ok but I think could be improved with some settings adjustments - anyone got any good prebaked settings to get the most out of HDMI in? (does it natively set at 1080?)
- Currently able to get HMDI A up by replacing the default CAMERA input on AV6 and swapping it out. I can't get AUX to work with anything else. Again, maybe this is an issue with the Beo 4?
- Lastly, which could actually answer a bunch of the above - am I using the Beo 4 wrong? Or are there settings I can change? I looked up how to reset the Beo 4 but the instructions seemed to be for a newer version.
Sorry this is a bit of a jumble - I consider myself normally quite technically literate but I am an absolute immigrant to the B&O universe! Thanks in advance for any help/thoughts!
