Beovision 7 40 Mk 3 Motorised Stand Operation
Hi All - I have just inherited my fathers B&O TV and system - very cool!
I cannot seem to get the motorised stand to work - I have plugged it in and the remote 4 does not show stand in  list? so I cannot adjust angle ? Any ideas - thx Chris
Thanks Lee - that worked but now the surround speakers which were working are not functioning? Its incredibly complex! Thx Chris
Because you reset the TV, you reset the speaker configuration. Don't worry - it can be fixed with a few button pushes 🙂
Go back into settings and tell the TV it has surround speakers.  If you have the user manual it will tell you exactly what to do.
Lee
Hi Lee.This is not working for me.Not just on one,but 3 x beovision 7-32's with the speaker etc.
Tried everything you suggested incl factory reset but getting nothing,not a jot from the stands,
I saw 2 of the three stands work and turn etc when collected but now when reconneceted,absolutely nothing.No stand references coming up in the menu at all.Am I missing something? Thx.Alan
Hi Lee,
Just asking, how do you reset the TV ?
I have a BeoVision 7 32" and I can't find the reset button.
Thank you for helping !
