Beovision 7 40 link to other room
I have:
BV 7-40 type 9361 in my main setup
BV 7-32 type 9314 at my bedroom
BV 7-32 type 9311 in the kitchen
BV 6-26 type 9200 in my office
Else I have a BS 3000 in my livingroom and some BL3500 around the house.
I get sound where I want it, but I cant get the TV-link to work properly anymore. It worked before I got my BV 7-32's
Main BV 7-40 is set to option 2 and all other BV's are set to option 6
When I go to the link frequency on the BV740, I get the test image on the other BV's for a second and then they tune out. If I change the frequency I again got the test image for a short time. The test sound however is there all the time.
Any ideas what I have to check?
In the BV7-40 manual it does state that HD sources are not distributed to link rooms, only SD signals. This is normal on B&O's link system, and is apparently for copyright reasons.
Thanks for the notifiication, now I found a solution.
I can use my TRRS-cabel to supply sound and picture at the same time as I use the DVI input. Then the main BV is digital and the other are analogue.
This must be the trendy analogue transformation I've heard about[ :)]
