Beovision 7-40 audio with HDMI
I'm renting an apartment with beovision 7-40 and holy lord I'm on a nervous breakdown from trying to connect video and audio to this TV.
How can I connect my ps4 with HDMI to dvi-i converter and get audio??
I see digital audio input? What cable do I need to connect there? I brought digital audio cable and surprise, surprise it's not fitting.
Hi lukanas17 and welcome to Beoworld.
There are several versions of the BV7-40, so not that easy to answer.
However since you mention DVI it must be a version 1 or 2 - but even there there are differences.
You need to connect the R/L analog audio-out that you would get using a HDMI extractor/converter to one of the inputs on the tv.
In some cases you can use a digital coax connection.
Do you already have a picture using the DVI input?
A version/typ number and/or a photo of the input section on the BV would help to guide you further.
It's class 1 so I guess version 1?
I do have picture with HDMI to DVI-I, only problem is the audio.
https://ibb.co/D8fmRgV
https://ibb.co/bBQD81p
https://ibb.co/PGdGv6C
https://ibb.co/8gjgg2t
Perfect!
It is a MK2.
You will have to configure the AV4 port and add sound seperately.
Which converter are you using from the HDMI output, do you have sound there as well?
(If yes,) is this an analog output or a coax digital or maybe both?
I’d try the analog R/L first.
You can find the Reference Book
Have a look at page 67.
I assume that you have the Beo4 remote as well.
You might have to configure that in order to have the needed ir command ready - please ask or consult the User Guide of the remote.
Thank you so much for helping me.
The HDMI to DVI-I converter is without audio output(picture at the link)
And here are the cables that I have left from previous owner
I'm guessing tulips to aux and tulips to tulips?
And I have a really weird long cable that I never seen before. From aux to some light bulb? Maybe some kind of transmitter?,
So can any of these help me and if not what is the best choice for me to get the audio? Thanks again!
Pictures:
https://ibb.co/F078gjN
https://ibb.co/S33nbwM
https://ibb.co/TvSksVJ
Pictures:
This is a PUC IR emitter, if the TV is set up correctly and you attach something like ATV or Sky box, if the TV has the item listed in the PUC menu you put  the emitter on the attached  equipment and you can control it using the B&O remote.
Stoobie
Exeter,
Devon,
UK
Pictures:
The first one....I have no clue what that might be - is it fixed inside the tv somewhat?
The second one - simply two audio cables (analog L/R). One is Cinch/RCA at both ends - the other Cinch at one and minjack at the other.
The last one is already explained - you won’t neeed that when you only want to connect PS.
N.B. Did you read the Reference Book, that I posted a link to?
Tell your landlord that this tv should landed in the scrapyard a long time ago ...
Tell your landlord that this tv should landed in the scrap yard a long long time ago ... 🙂
Millemissen and Stoobietoo a really big thanks! Helped me a lot!
